Daz Studio crashes at beginning of rendering.
![rudolph_corey_102f945590](https://secure.gravatar.com/avatar/1d2e4e6dfdbbdc224edcf79a54e6f06a?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F1d2e4e6dfdbbdc224edcf79a54e6f06a_100.png)
Hi, things went fine until suddenly daz studio just crashes at the beginning of iray rendering. I updated my graphic card drivers but didn't work. The scene is just genesis 8 with a few clothes on with Paper Tiger's True Studio HDRI Lighting. I attach the log file.
txt![](/forums/plugins/FileUpload/images/file.png)
txt
DazLog.txt
1M
Illegal memory issue is usually ralated to driver issue, flawed assets, and physical card failure. As per what you described, try below in sequence:
- remove all clothing on the figure and render. Or just load a bare base figure to render.
- use DDU to completely uninstall Nvidia driver and residuals, then reintall a fresh Studio Driver.
Then let's see what's gonna happen...
Well, I'd used the DDU software to unistall and reinstall the graphic card drivers and it still crashes. But when I'd render with just genesis 8.1 figure in the empty scene it didn't crash.
Yes, one or some of the clothing / accessories that you used may have issues. Even a flawed texture map in TIFF format can cause DS to crash. You may check the clothing by a method of elimination... or name what products that you used.
