Can I downgrade Daz Studio from 4.22?
Running 4.22 on M1 Mac
The new upgrade will not allow me to use the upper menu "EDIT" and scroll down past "DUPLICATE" without the menu vanishing or flickering. If I attempt too often, the software crashes. This is the primary reason I use DAZ is to get to EDIT/OBJECT/MORPH LOADER PRO or EDIT/FIGURE/MORPH LOADER PRO to finish building in Blender. But now these functions are not accessible to me. There is no way to mouse over these selections.
I get that DAZ does not really support MACOS, but at least the last version was workable.
  • SofaCitizenSofaCitizen Posts: 1,951
    Not unless you have saved an earlier zip file.
    As a work-around you can re-organise the menu and/or assign hotkeys to get at those functions. Press F3 to launch the Window/Workspace/Customise dialog.
  • AgitatedRiotAgitatedRiot Posts: 4,437
    Only if you kept the original executable to the lower version.
  • Richard HaseltineRichard Haseltine Posts: 102,309
    That seems a bit extreme, even if I can understand your frustration. But daz has made considerable efforts to support the Mac, despite the shifting hardware and OS environment. This isn't an issue I have seen widely reported - have you tried disabling third-party plug-ins, in case the issue lies in one of those - http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/plugins/plugins_load_config/start ? If that isn't it, if it is a core issue, it is certainly worth a report (to support, or if it affects the beta too then to the beta thread as well)
