Where is the Decimator Plug-in?
neoman
I purchased the decimator plug-in with DIM and it is nowhere to be found in Daz Studio 4.22. It is not in the Window-Panes bar where it should be. what the heck is going on???
You can't purchase a plugin with DIM. I assume you meant you installed it with DIM. Check in Help/About Installed Plugins. Is Decimator listed there? Does it have a green plug? Has your Decimator Serial Number been entered?
You purchased it with DIM, or you installed it with DIM? Check Help -> About Installed Plugins to see if it's there, and if it needs to be activated.
Yes... INSTALLED it with DIM. Sorry.
Thanks, that was it. Just needed to insert the serial number. Thanks again!
A quick fix is always good!
