hair doesn't fit
dondrawdondraw Posts: 104
i back aftrer being elsewhere a while. getting used to daz again, installed a character, femme, and tried to put hair on her, tried several hairs and they balance atop head like weird hat and don't fit. what do?
drawnimage
  • dondrawdondraw Posts: 104
    weird, i tried copy and paste to put image in note, but that doesn't seem to work. how put screencap in query?
    dondraw
  • felisfelis Posts: 4,692
    You have to attach your image, by clicking the attach button, and then browse to your image.
  • SofaCitizenSofaCitizen Posts: 1,970
    You cannot paste an image into the body as that will not work. Under the editor box is a link to "Attach a file" - click that and then use the browse button to select your image to attach to the post.
    As for the original issue you are having - make sure you have the figure selected in the scene to ensure the hair is parented and fit to it when it loads.
  • frank0314frank0314 Posts: 14,330
    At hte bottom of the text field there is an "Attach"
  • dondraw Please specify what kind of Figure you are using, per example, Genesis 8 or Genesis 9 Female.
    Also, the type of hair you wish to use.
