Ground Level Renders Dark in Fog - Halloween Forest
![Escribano](https://secure.gravatar.com/avatar/1734bdad57e8c2eea6ce41701c2629b8?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F1734bdad57e8c2eea6ce41701c2629b8_100.png)
I have been trying to resolve an issue with my renders of the Halloween Forest.
It uses the Matte Fog and Ground Fog effects in the Environment Options. When I render it with out-of-the-box render settings, the area above and below ground level render at different brightness, creating a start delineation in the fog (see attached image). If I turn off the matte fog, the dark dilineation goes away. The ground fog does not seem to contribute to the problem.
Is there a way to fix this issue by adjusting the enviornment settings without losing the matte fog?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/6e/3bb5ca2d1ac26c1eaf69b3c85acac9.png)
1920 x 1440 - 4M
Check this thread and try the settings ...
https://www.daz3d.com/forums/discussion/639556/help-about-the-halloween-forest-environments-have-picture
Thank you! That pointed me to the setting I needed :)
