Missing Files - Outoftouch's new Turbulent Warrior hair
Serenity's Gate
Maybe someone can help me get these files ??
Their missing from the zips i downloaded
Thanks
Tom
912 x 382 - 41K
912 x 371 - 33K
If they are missing and required then only Daz may provide them, please open a suport ticket. I just loaded the base hair and didn't get that prompt, however - what were you loading at the time? Edit: OK, it happens with the A version but not the B - I would suspect that may be a file error in the A version rather than actual missing files.
I wasnt loading anthing ? I used DIM initially - then uninstalled and deletd - then attempted again - then did a manual download and install in my library - same issue - thanks
Thats correct - it also throws that error when you go to apply materials
you are not alone i have the same problem
don't have this product - so this just a [wild] guess
search for those files in the duf and see if those files have a
"//" at the start of the file path
it should be a
"/" ............................................not //
If the path starts with data, or Runtime for textues, it probably isn't that issue - though it could be mid-path.
Same problem here. Reinstalling did not help. I will try contacting OOT and point him/her to this thread!
There hasn't been an update so reisntalling won't yet help.
There is an update of the product now. It solved the problem for me.
