dForce Little Cutie Sweater G9 from Svea does not work
![Moin3D](https://secure.gravatar.com/avatar/a041fb5daa17f3bd94ab64b10d280fe7?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fa041fb5daa17f3bd94ab64b10d280fe7_100.png)
Hi,
I purchased the dForce Little Cutie Sweater G9 from Svea and installed it with the latest version of DIM and in a second try via Daz Connect. It appears in my Smart Content but when I try to apply the wardrobe on a G9 figure nothing happens. Anyone else with this problem?
Kind Regards
Torsten
If you have installed it both with DIM and Connect you have 2 seperate installations, and Connect will take precedence.
And I wouldn't expect it to have metadata, as it is a part of the bunch transferred products.
What does your log say when you try to apply it (Help > Troubleshooting > View Log File)?
I didn't installed via DIM and DAZ Connect at the same time. Before I tried the other way I uninstalled the previous version.
Here is the log:
2024-06-22 08:47:19.364 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Clothing/Sveva/dForce Little Cutie Sweater/Materials/!AC Little Cutie Sweater.duf
2024-06-22 08:47:19.364 [INFO] :: Locking viewport redraw...
2024-06-22 08:47:19.364 [INFO] :: Viewport redraw locked.
2024-06-22 08:47:19.418 [VERBOSE] :: Native format content directories: 10
2024-06-22 08:47:19.418 [VERBOSE] :: Poser format content directories: 2
2024-06-22 08:47:19.418 [VERBOSE] :: Other import format content directories: 0
2024-06-22 08:47:19.418 [INFO] :: Begin asset load (merge): /People/Genesis 9/Clothing/Sveva/dForce Little Cutie Sweater/Materials/!AC Little Cutie Sweater.duf
2024-06-22 08:47:19.428 [INFO] :: Determining missing assets...
2024-06-22 08:47:19.469 [INFO] :: Setting textures...
2024-06-22 08:47:19.469 [INFO] :: Creating materials...
2024-06-22 08:47:19.469 [INFO] :: Applying animations...
2024-06-22 08:47:19.486 [INFO] :: Finished asset load (merge): 0m 0.67s - /People/Genesis 9/Clothing/Sveva/dForce Little Cutie Sweater/Materials/!AC Little Cutie Sweater.duf
2024-06-22 08:47:19.612 [INFO] :: Unlocking viewport redraw...
2024-06-22 08:47:19.612 [INFO] :: Viewport redraw unlocked.
You are trying to apply a material, not a clothing item.
If you are using Smart Content (or Ctaegories, or the presets tab of a settings pane) try right-clicking on one of the files and selecting Show Asset In>Mapped Folder (or possibly Virtual Folder as the labelling has been bugged and is fixed only in the Beta versuion of DS at the moment). That should take you to a list that shows how the files are on disc, the clothing model will usually be in the parent folder for the product with the materials in a sub-folder.
If you use DIM to install the products you bought, suggest you not use Daz Connect anymore. In principle, better just use one of them only.
Thx for your hints. The product in the "Smart Content Tab" isn't properly categorized as I would expect this like all the other products from the DAZ shop. Under "Wardrobe" is a material preset "!AC Little Cutie Sweater" only like Felis said. I thought this would apply the clothing but didn't get it. In the list "Lost and Found" is the right preset "dforce Little Cutie Sweater G9" within the other material presets. The other way would be like Richard said.
Now I can use this product but it should be fixed with the usual categories to prevent confusion like this.
I appreciate your help!
Torsten
This wasn't the problem. As I wrote: "I didn't installed via DIM and DAZ Connect at the same time. Before I tried the other way I uninstalled the previous version."
Oh, I missed that point. Then no problem !
The issue just comes from wrong metadata. I bought this one on Rendo and install it myself with Content Wizard, so there was no such issue.
You may use ContentDB Editor to add Content Type to them, as well as adding Categories in RMB-Click menu, in Smart Content.
Then submit a ticket... but I think some folks have already done so ~~
Thanks anyway!![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
