Saved smart props not loading with textures.
I had a model I brought in from Poser. I saved it as a support asset prop. It can be loaded in and does have textures, but it is in the center of the floor. The moment I move and position it and parent it to a right hand of a figure and save it as a support asset. Now when I open that one it has no textures.  Any help is appreciated, thanks.
  • crosswindcrosswind Posts: 8,102
    You saved it as a Prop asset for two times ? You should've saved it as a Wearable Preset after positioning and parenting it to the figure's hand.
    But even if you did the former, the texture would be still there unless you did something wrong. Better post some screenshots to illustrate how you did it.
