How can I delete an actor created to G9?
CHWTCHWT Posts: 1,181
How can I delete an actor created to G9? I managed to screw up using the G8 to G9 character converters and now there is an added actor (due to the screwed up conversion) which I do not want. Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 101,824
    If you mean a morph you need to find the .dsf files in data/daz 3d/Genesis 9/Base/Morphs/ - if you click the gear icon on the slider and open Parameter Settings that will give the path. If you created a full new figure then you would want to remove the whole of its folder in the \data folder, and any presets pointing to it.
  • CHWTCHWT Posts: 1,181
    Got it, thanks a lot Richard
