Selena hair has dforce settings?
SnowSultanSnowSultan Posts: 3,619
https://www.daz3d.com/selena-medium-hair-for-genesis-9
This hair doesn't mention being dForce, but it has the shader parameters set as if it did. Can someone confirm whether this is dForce or not, because I always get an error if I try to simulate with it. Thanks.
  • I get an error trying to simulate too:
    2024-06-27 20:53:27.407 [INFO] :: Found 1 unused vert(s) on the geometry of node "Selena Medium Hair". Removing unused vert(s) from sim.
    2024-06-27 20:53:28.329 [WARNING] :: ..\..\..\src\dzdynamicsengine.cpp(2691): ERROR: clCreateBuffer (-61)
    Description seems to suggest that that it has at least some strands to simulate. Interestingly, when I apply a very obvious omni hair shader (blue) from a different product to all the surfaces, the colour doesn't change from the base load (except the cap, which is blue).
  • SnowSultanSnowSultan Posts: 3,619
    Thank you, that error does make it sound like it was intended to use dForce in some way. I guess we'll have to wait for clarification from the creator or someone else at DAZ.
  • crosswindcrosswind Posts: 7,483
    Colors with Omni should be seen if you NVIDIA Iray preview in Viewport.
    As for simulation issue, I'm afraid you have to submit a ticket. Users have no way to resolved this sort of issue on an SBH...
