Can't render
lou_harper
I spent all day setting up a scene. Now when I hit render I get an "can't render" error message. This is at the bottom of the log file:
2024-06-27 17:32:12.345 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - API:DATABASE :: 1.0 API db warn : Transaction is released without being committed or aborted. Automatically aborting.
2024-06-27 17:32:19.072 [INFO] :: Total Rendering Time: 12.13 seconds
What the hell is going on?
Have you tried saving the scene and restarting DStudio?
Many times. :(
I have to reboot the PC every time too, becasue DAZ doesn't close properly or crashes after a failed render attempt. And as I do, I get this error message. But then the pc restarts without me clicking on anything.
After much tedious testing I zeroed down to one prop. Once I removed it from the scene it rendered. :/
Hmm, it's an asset issue...
It was the cauldron from Halloween Props, but I used it many times before without a problem. Also tested it again with a fresh scene and no issue. So something must've gotten corrupted.
NvContainer... would most likely be part of the nVidia driver, which might well explain why the issue has only just started. Which (or witch) Halloween props?
A set by Hypertaf–not in the store anymore. But as I said, it works fine.
