Hawaiian grass skirt for Genesis figures that is not dForce?
I am wondering if there is a Hawaiian grass skirt for any generation of Genesis figures, or even Victoria 4, that is not the dForce variety?
The reason I ask is that I would like to have the grass skirt be grass strands and not dForce hair based, as I had some trouble with rendering with a pwToon shader, and I would like to have a version that I can easily use a toon shader on while the girl is hula dancing.
Also, while I am at it, any hula dancing animations I can get for Victoria 4 or any Genesis figure G2F and up?
  • LeanaLeana Posts: 11,817
    The only one I know is for Dawn: https://www.renderosity.com/marketplace/products/146306/hula-for-dawn
    There used to be a Genesis version IIRC but it's not available anymore.
  • FirstBastionFirstBastion Posts: 7,830
    Perhaps a long grass texture on a regular conforming skirt might be the solution here.
  • I'd like to ask, the one for Dawn, is there a script that can convert Dawn clothing to the Genesis version?
  • Richard HaseltineRichard Haseltine Posts: 102,351
    That would reqyuire an AutoFit clone for Genesis whichever made by, or with permission from, the owners of Dawn (because it would match their figure's shape). As far as I am aware no such clone exists.
  • DiasporaDiaspora Posts: 454
    I've used the dawn skirt before on Genesis 2, basically all I did was use the hip node and a little bit of scaling to basically move the skirt to the correct position over g2's hips and then I 'froze it' in place by clicking edit > figure > rigging > convert figure to prop
    then after that I click edit > object > rigging > convert prop to figure select tri ax weights
    finally I click the skirt that is now a figure and edit > figure > fit to and then click unsupported under figure type and skirt knee length
    This way I'm able to create usable clothing usually even if I don't have a clone handy. Sometimes I will have to modify the clothing after the 'convert figure to prop step' in a 3d modeller program (I use Maya but Blender these days is good enough for a lot of stuff) to get it just right but yeah, try this out. It's a good outfit.
    There's not autofit clone available to convert between Dawn and Genesis figures. It's possible to create one yourself though.
    Since it's a rather simple skirt maybe you could try parenting it to your figure's waist without fitting it, then adjusting the pose manually.
  • felisfelis Posts: 4,617
    edited July 2024
    I tried to model a somple hoolaskirt.
    It kind-of works but also has some issues.
    1200 x 1200 - 2M
    Post edited by felis on
