Dforce not following adjusted clothes dimensions?
RobertDy
So I tried dforcing a skirt that I modified in length using Fit Control morphs. I noticed that no matter how short or how wide I made the skirt, the end simulated result always goes back to its original length. What's going on here?
Are you using an animation maybe? In that case the morphs might have been set for frame 1 but not for the last one?
EDIT: I thought I was doing a still frame but it turned out that it was an animation. Thanks for the tip, it's solved!
