(Released) - Elis Hair for Genesis 9 [Commercial]
ToyenToyen Posts: 1,906
  • So i grabbed this today and was eager to test, in the promos it is shown that the bangs can be hidden and the script does hide them in texture shade, but in iray the bangs are still there. The omnihair shader doesn't seem to support opacity, but it's shown in the promos so there should be a way to make it work, right? Any ideas?
    1507 x 862 - 2M
  • ToyenToyen Posts: 1,906
    Hello there!
    It appears the material options for the bangs seems to be indeed set up improperly. I apologize for the inconvenience. Somehow my tester must have missed that.
    The way you hide the bangs is you manually select both material zones ('Bangs' and 'BangsStrays') and set both "Line Start Width' as well as 'Line End Width' to 0.
    Thank you for alerting me to this I will submit a fix for this product as soon as I can.
    Hello there!
    Thank you for the quick response, yes that did indeed work, cheers :D
  • Not me near spitting my drink out when I saw this in todays email XD I was obsessed with this hair as a teen. I'm still waiting for my sister to get back from work so I can show her!
    Elis, famously the sister of Eduerd. If you happened to find the time to make a Yazper hair circa film 2-3 I have my piggy bank and hammer ready.
  • I seem to be missing the purportedly miraculous OmniHair Shaders, it certainly doesn't look anything special with the Daz default shaders it is loading with.
  • Richard HaseltineRichard Haseltine Posts: 102,344
    Have you missed an update to the Default Resources package? If yours is up-to-date, are you sure that there isn't an older version installed that is being loaded first (throught Daz vs through DIM, or in an old content directory that is checked before the current one)?
  • edited July 2024
    Thanx for your suggestion Richard. I downloaded & reinstalled Genesis 9 Starter essentials after encountering the problem but that didn't help (& when I looked in the zips manually there was no sign of ant shaders. If there is an errant older version (possibly from DazConnect ), I'm not sure how to locate it
    When I load the hair I go through a missing file dialouge process which seems unusual but doesn't keep asking for missing files when I click ''Install''
     I'm on Daz version 4.22.0.16 which I hope is current, any further suggestions would be apreciated.
    Adain , thanx
    1153 x 877 - 417K
    2024 x 1252 - 416K
    1388 x 899 - 268K
  • chevybabe25chevybabe25 Posts: 1,272
    You need to install "default resources" not "genesis 9 essentials"
  • edited July 2024
    chevybabe25 said:
    You need to install "default resources" not "genesis 9 essentials".
    OK thanx, I'll try that after work
    8-)
  • Thankyou chevybabe25 (& Richard H) that worked perfectly, Elis Hair now looks much more realistic & I am un-frustrated.
    (& still waiting patiently for MeshGrabber 4     cool   )
  • jd641jd641 Posts: 459
    The hair looks great, but is it a dforce hair? There's the generic dforce video in the description but there's no mention of simulations anywhere else.
  • LeanaLeana Posts: 11,817
    It lists "dForce Hair" as compatible software so it should be.
    The technology used to create the hair is dforce hair technology but the hair does not drape.
  • tsroemitsroemi Posts: 2,867
    O - M - G, my brain is such a soggy toast. After literal DAYS of pondering your post, I finally got what you were referring to - and remembered where I know the hair from ...blush
