Mirror problem
The rearview mirror on the car in this scene didn't come with a mirror texture, so I gave it one and the resulting image is less than good.  After looking at it in wireframe mode, I can see that the mirror surface is a result of the structure of the mirror.  (It follows the triangle-shaped faces.)
I've tried messing with the geometry editor in Daz, but it only lets me select it and if there's anything else I can do, I'm not aware of it.
Any suggestions for getting an actual clear mirror image out of that mirror?
1250 x 938 - 102K
  • crosswindcrosswind Posts: 8,097
    You don't need any texture map on a specular surface in this case, e.g. a mirror.... Just set Metalicity to 1.0, set Angle to 15 ~ 30, on mirror's surface.
    1471 x 1294 - 1M
  • Thanks for your input, but I guess I mispoke.  I didn't put a texture on it, I used the polished aluminum iray preset which already has the settings you described above.
    The reason for the weird result is the surface itself.  I attached a "hidden line" version of the mirro and you can see why.  I have a feeling the mirror on your car is a nice uniform surface, unlike the one on the car I'm using.
    I'm wondering what would be the best way to overcome this problem... if there's a way at all.
    683 x 919 - 447K
    edited July 2024
    Oh.. such a topo... It seems not a Daz store product. The attached is mine.
    I don't have similar item but you may try with different Angle Values... or cut that surface with Geometry Editor, and send it to Blender for a remeshing.
    1471 x 1294 - 1M
    Post edited by crosswind on
  • I thought about trying to send it into Blender, but my knowledge of Blender is limited, to say the least.
    Any tips?
  • eeyuneeyun Posts: 26
    You could just fix it in post.
    Add a plane primitive in DS, just in front of and just large enough to cover the mirror surface, and apply your mirror texture to that. Re-render, cut and paste.
    edited July 2024
    Any tips?
    Have you tried setting different values of Angle... it still didn't work ?
    Anyway, if you want to remesh the mirror in Blender, try these steps:
    - In a new scene, load the car. With Geometry Editor, select the surfaces of Mirror only, Ctrl + /, Delete Selected Polygons. Export the mirror to OBJ and Import it into Blender. (ss1 ~ 2)
    - Use QuadriFlow Remesh to remesh the mirror. Export the mirror to OBJ. (ss3 ~ 4)
    - Import OBJ into DS, the scene you're making, add SubD as you wish and parent it to the Car. Hide the original mirror surface and test the render (ss5 ~ 6)
    2560 x 1392 - 2M
    2560 x 1392 - 303K
    2560 x 1392 - 617K
    2560 x 1392 - 655K
    2560 x 1392 - 296K
    2560 x 1392 - 955K
  • kprkpr Posts: 121
    Another In-Post solution... (no plane)
    • Do your main render
    • Put a camera in the wing-mirror
    • Do another render using that cam
    • In [image editor of choice] open both files
    • Select/Copy R2 into R1
    • Position R2, then muck about with cropping/sizing/skewing etc
