Render hanging at end ...
Lately, since the last beta update, some renders (not all) seem to finish (I can tell when the graphics card noise winds down) but then the save option takes up to 10 minutes to pop up. Doesn't happen on every frame of the same animation scene, just seems random. Anybody got a clue? Anybody else experiencing this? Attached is the log data from last render when this happened. Says it rendered in 15 minutes but took another 10 before I could save it.
txt
txt
Log File.txt
36K
  • crosswindcrosswind Posts: 7,821
    Have you tried just rendering with your graphic card only rather than with both card and CPU?
  • No. Normally only the GPU is used but I'll give it a try and report back.
  • Turned off CPU fallback so only using GPU. That seemed to have solved the lag between render finishing and save option popping up. However, it lengthened the overall render time from 15 mins to 23 mins so still taking the same amount of time to finish. Guess I'll just have to live with the longer render times on this one.
