atio6axx.dll causing critical errors
I've already raised this as a bug report but not received a response yet. I have 2 PCs, one which has an RTX2070Super GPU on an intel based CPU, the other has an AMD 6750XT on an AMD CPU board. Obviously since DAZ and AMD GPUs don't play with each other I do most of my renders on the nVidia card but with only 8 GB of VRAM it won't render scenes with more than 2 gen 8/9 chars in it. I therefore render those scenes on the AMD PC as it has a significantly faster CPU and more memory. It's a much more modern build. This was working just fine for me untill a week or so, since then the minute I load in an environment I get the following error:
This is a huge issue for me because I also use that PC to set up scenes while the other is rendering. I did some research and it points to AMD driver issues. I ensured I was on the latest and greates AMD drivers, see below:
Does anyone out there have a fix for this?
528 x 511 - 32K
330 x 190 - 16K
  • Richard HaseltineRichard Haseltine Posts: 102,309
    If the issue started only a few weeks ago then it is probably the fault of the updated drivers - try rolling back to drivers issued before the problems tarted.
    Easy said than done. Rolling back drivers is not a fix and will effect negatively other things I do with that computer.
