How do I freeze the results of the last simulation
kyoreona
Hi, everyone
G8 is already dressed in dforce costumes and has executed the simulation.
Now I want to put a dforce mattress on G8's body, how to keep the last simulation results of G8 and his clothes locked and unchanged during the second simulation.
1526 x 1070 - 890K
For each item you want to freeze, go to the Parameters tab, and turn General > Simulation > Freeze Simulation on.
thank you.
I only found the parameters you mentioned on the clothes, not in the parameter of the character
How to make a character completely freeze during simulation.
For example, there are two characters in the scene, and Character A has been simulated before, how to make character A and his clothes completely frozen, and only simulate character B
When I am not satisfied with the simulation result of B and click the clear button, the simulation result of character A, which was frozen before, will also be restored.
Very upset
Even if you own no dForce Companion ( https://www.daz3d.com/dforce-companion ), you don't have to Freeze figures / items one by one ~~
Hold Ctrl key firstly, then select the figure and the clothing you want to Simulation. Right-click on the tabl of Simulation Settings > Simulated Selected.
Then, only the seleted items will be Simulated.
thank u ! I don't know this way , I will try
You also need to select the things you want the clothes to collide with - anything you don't select will be completely ignored.
