Why did they remove Brow Inner Up/Down But Kept Inner Brow Up??
lioncrudlioncrud Posts: 25
edited July 2024 in Art Studio
[Why did they remove Brow Inner Up/Down But Kept Inner Brow Up?] Such a basic and common pose, was this a mistake that was overlooked and no one has noticed yet? Literally a step backwards from G8. So confusing.
  • Richard HaseltineRichard Haseltine Posts: 102,130
    Moved to Art Studio as it is not a Daz Studio topic. Edited to add question to body of post.
  • NorthOf45NorthOf45 Posts: 5,529
    Try Nose Sneer Upper (Left/Right). It hardly affects the nose, mostly the nose bridge and inner brows.
  • HylasHylas Posts: 5,060
    https://www.daz3d.com/forums/discussion/477386/how-to-get-genesis-8-expressions-working-on-genesis-8-1
    I recommend this, having 8 and 8.1 expressions at your disposal really gives you a lot of possibilities!
    Except that the first post gives the wrong instructions (talks about deleting stuff in the FACS folder)
    Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
    The dummy/placeholder files are located in;
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
    Note 1; If you are logging in to DS and letting DAZ Connect (within DS) to install/update your content, you may have these also in an other location that has "\Data\Cloud\" in it's path
    Note 2; Do not remove any files from "FACS" or "FACSExpressions" folders
  • nonesuch00nonesuch00 Posts: 18,263
    Yeah, I did not like that ommision either. Some Most people can do that.
