Help! How can I get back to Face Transfer 1?
![Speculativism](https://secure.gravatar.com/avatar/fb1f6abb6810464bbd95a338e51f4a85?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Ffb1f6abb6810464bbd95a338e51f4a85_100.png)
I've got a registered copy of Face Transfer 1 but when I try to use it recently I keep getting the trial version of Face Transfer 2 instead. I don't know how to make the trial version go away and bring back my registered version of Face Transfer 1. Does anyone have the solution?
From what I've read, it should automatically use Face Tranfer 1 when you use G8 and 2 when you use G9.
Yes, the figure used determines which you get (Face Transfer 2 is more than just a Genesis 9 update, but nevertheless that is a ket difference ebtween them https://www.daz3d.com/forums/discussion/662091/face-transfer-2 )
Thanks. I'm still not sure what the problem is but I've got a few possibilities which I'm investigating. I started with no figure selected and it went to Face Transfer 2. It did not give the option of using genesis 8 so I'm looking at whether the installation of Genesis 8 is broken somehow.
You should be able to seelct Genesis 8 Male/Female as the target in the pane (it's the same pane whichever pluginis being used).
Thanks Richard and Leana. I'm old and forgetful.
The problem was with my brain.
I had forgotten that Face Transfer 1 only works on my Windows computer and I was trying to find it on my Mac. I have the two computers side-by-side and some things only work on the Windows one.
I only realised what it was after I'd uninstalled and re-installed several things and was at my wit's end. Then I looked at the web page for Face Transfer Unlimited and noticed that it was Windows only.
Sorry to have bothered you.
