Character Not Saving Shape or Pose BUG
I've been bashing my head against a wall all day trying to figure out this problem. I'm going crazy, so I'm seeking help!
PROBLEM: Character not "saving" shape or pose when saving as a "scene" or a "scene subset". Parameter data not saving correctly?
I just created two new characters. As always, I finished them up and saved them as a "scene" and then after saved each of them as a "scene subset" to bring into other scenes later on. (I have done this a dozen other times with other characters without issue.)
Suddenly with these two characters, whenever I "save" them (either as a scene or scene subset), and merge them into a new scene they have no shape (they are base genesis 8.1) and they are posed in an old pose I used earlier on in their creation, instead of the default A-Pose that I set it to before I saved them. ALMOST ALL of the parameters that SHOULD be saved are all reset to their defaults, it's like everytime I go to save the file, it's using parameter data from days ago in an earlier file, including posing data.
The only way I can view the correct figure/shape/character is by opening the original scene. But any attempts to merge it into another scene, causes the problem.
I hope someone knows the fix. Please please help me! I feel defeated.
  • felisfelis Posts: 4,597
    Is the problem general, or specific to this scene? I.e. if you from another scene save a scene subset does that then work as expected?
  • crosswindcrosswind Posts: 7,821
    Though it's odd...(as it used to work well with no issue...),  but you can always open the saved DUF files with Notepad++, to check if there's anything wrong with in the file.
