Problem loading HDRI from smart content/content library
![ancanar_3dfb1cf89d](https://secure.gravatar.com/avatar/d94ca85194756deae5a07ff9371da9db?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fd94ca85194756deae5a07ff9371da9db_100.png)
Whenever i try to change HDRI from smart content or content library (for exempla go "Render Settings>Iray and try to loat any file ike DHTDR-MauiA) it shows progress bar but nothing happens afterwards. The Enviroment map in render settings is still set to default "ruins" one. What am I doing wrong?
That sounds wrong. I have that file and it should show a dialog box straight away asking if you want to save the current scene before it replaces it. Once you hit no it should complete within a few seconds.
Go to Help->Troubleshooting->View log file, delete the contents of that file (back it up elsewhere if you want) and save it. Then run that command again and when it stops doing something and/or after 30 seconds or so view the log file again and see if there is anything in there they may explain your issue.
This is what I get from running it
