Unable to increase the number of render iterations above 25,000
Cliffborne
Hi! I do not seem to be able to increase the maximum number of render iterations above 25,000, which is a bit annoying as my renders get truncated when I hit 25,000 if I use high render quality (6 or above). Any help would be appreciated. Thanks!!!
Tick "Use Limits" before setting Max in Parameter Settings of Max Samples property ~~
Thanks for your reply, but I do not seem to be able to open the window that I see in your screenshot. Where is it, please?
@crosswind If I click on the clog, I can only see the options Favourite, Hidden, Lock, and Reset value.
Click the little circle, that opens the window, the circle looks like a gear.
You may have to unhide the option, in the hidden one, you mouse over it and it gives you the option to hide or unhide.
Ah... I know why ~~ From a certain version of DS 4.22, the feature of Parameter Settings has been removed by Daz, by design...
You have to 1st of all get Parameter Settings back... Pls refer to this thread: https://www.daz3d.com/forums/discussion/658641/dforce-4-22-gravity-parameter-settings-missing-solved
