Adding a zipper to clothing texture
galatt
Hello,
I'm trying to add a non functioning zipper to a outfit. Do you overlay it on the fabric texture or is there more to it?
Thanks
Hello,
Thanks
The easiest way to do this would be to simply add a zipper in Photoshop overtop of the texture as long as the UV map is flat. Don't forget to also edit the bump map.
Well, you would want something to gie the appeaance of relief probably - a bump or normal map - and if possible you would want to model the recess in which it runs.
