v8 animation to v4
![gocuzero](https://secure.gravatar.com/avatar/050c6e5c7145fd7678ec7116a85164b7?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F050c6e5c7145fd7678ec7116a85164b7_100.png)
in The Commons
i need transfer some animation of v8 to use in v4 because i have a lower ram memory and is more faster use v4 charactar is possible exist some asset / tool script etc to buy or free that can convert animatio of v8 to genesis or genesis 2 or V4
You may consider this product - https://www.daz3d.com/bone-minion-for-genesis-8-and-81-poses-for-generation-4 which can converts both static pose and poses in animated range.
thanks will test
i buy it and WORK PERFECTLY exist the same for v3 figure gen 3 michael 3 aiko3 etc???? v3 to v8 v8 to v3?
Great ! Unfortunately, AFAIK, there's no Bone Minion product supports Generation 3 to whichever Genesis xx ~~
There's a bone minion genesis 3 to 8 converter: https://www.daz3d.com/bone-minion-for-genesis-3-poses-for-genesis-8-and-81
you typically have to buy two converters to go in both directions or a few to chain converter products together across generations.
This product is pretty expensive but it's also universal across genesis figures: https://www.daz3d.com/mocap
I've used it to transfer poses and animations between all sorts of generations. I think it's the only one that seems to be able to do that as a single product, so it's actually cheaper than buying many other other products. It's not quite as simple to use, but has worked very well for me. It sort of does expressions too, but not fully. I've not tested that part beyond the superficial, but it does seem to do slight expression transfers that other products can't do. I think it calculates the bones offset by an expression morph (vendor probably adjusted rigging to shape?) rather than the morph shape itself. I was getting eye and mouth movements out of it, anyway.
There is a freebie pose transfer script that does V3-G8 and another G8-V3. They can occasionally be a little unreliable due to the wide differences in generations, and often needs limits turned off. It doesn't help that they are not targetted at animations, but they may be useful.
Regards,
Richard
thanks will test.
