Problem with a light I can't select.
![Uncommon Role](https://secure.gravatar.com/avatar/6ecbc8f2fd5f2cf333f94e2cfa7d6525?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F6ecbc8f2fd5f2cf333f94e2cfa7d6525_100.png)
Hi! I've started a new scene with this asset, and there's a light coming from a fan that I want to edit, both in color and intensity. Normally, I would select it and go to surfaces and emissions, as I've always done, but the problem is that I can't select it; it's as if it doesn't exist. I'm attaching screenshots to show that there's light in the render, but nothing to select. Any ideas?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/f3/1cbb3dac80a7115a31f813c3350c80.jpg)
1913 x 971 - 414K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/19/af24db977d539b22c037228ed1d0e3.jpg)
1913 x 971 - 414K
Under the root node of the crime scene, go to "RCS Scene light group" in which there's a point light "PointLight (4)". That's it ~
Because its property "Visible in Viewport" is turned off, so you could not see it with texture shaded drawstyle. Just turn on Visible in Viewport.
As always, many, many thanks
No problem ~![yes yes](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
