Parameters Sort Order Reversed?
jim_doria
I have no idea how this happened, but suddenly the parameters in the Parameters panel seem to be showing up in reverse sort order. I'm not sure it's exactly 100% reversed, but properties that I'm used to seeing at the top of the list now occur at the bottom and vice versa. For instance, when I click on G8 head --> Pose Controls --> Eyes the list now appears as:
- Eyes Up-Down
- Eyes Squint Widen Right, Left, both
- Eyes Side-Side
- Eyes Relax Right, Left, both
Etc. The Eyelids Lower options (Up-Down Right, Up-Down Left, Up-Down, in that order) are at the bottom.
How can I get the list back to the correct A-Z sort order? I can't find an option to change it in the menus. TIA!
I used to have the same issue before... not only in Parameters pane but in Surfaces pane as well ... Have you applied any Preset file (and/or even undone then...) before seeing this issue ?
Normally if you reload the scene file, properties will be well sorted by Label in ascending order (under a single Path without any sub-path...)
It may have been a temporary glitch. I'll have to check next time I load the scene.
