G8 Short Wet Hair - Wet Skin Geoshell on G3 Male Gens?
Anxious3102
Does anybody know if there's any way to make the wet skin geoshell that includes genitals from the "short wet hair" set for G8, work with G3 male genitals?
You'd have to add your own shell and copy the materials over, probably (select surface, Edit>Copy>Surface, then select surface(s) on the G3 shaell and use the paste surface option).
This worked! Thank you for the tip! I was able to steal a shell from a different set and copy it!
Create>New Geometry Shell, with the figure selected, will also work.
