I messed up the teeth with some morphs... how do I overwrite them?
I used this excellent tut by @CGI3DM to fix teeth in a bunch of morphs I made.  But when I tried to save as morph assets again in the same Daz content directory with same names, they didn't overwrite.  How do I overwrite them?
https://www.daz3d.com/forums/discussion/380576/applying-head-morph-teeth-issue-genesis-8-female#latest
  • crosswindcrosswind Posts: 7,821
    How did you fix them and save the morph assets ? The link you posed could not be found... but if saving the existing morph assets, the morph dsf files should be overwriten as long as they're writable... any error message or show your DS log ?
  • Gator_2236745Gator_2236745 Posts: 1,312
    I'm not sure.  I didn't realize that link is in a Daz+ member area, that's probably why.
    I think I fixed it?  Also it seems like they may have been updated, but the filesystem (Windows 11) didn't show a modification in the time.  So I assumed it didn't happen.  What I did was shut down Daz Studio, then copy the morphs to my Daz content library from my personal one and delete the personal content library morphs.  Then I edited the morphs and saved them out to my personal content library.  Shut down Daz again and delete the ones in my Daz content library.
    I think changing properties of the morphs is written, because the whole deal is from the "Mouth Realism" morph.  By default it loads on my Genesis 3 female.  So I went into the morph properties, edited it, and set it to zero.  That seemed to stick (I've shut down and started up Studio many times now and kind of tired, so I'm not 100%).
