Medina Cityscape Generator but China
nynico_8c2302db09nynico_8c2302db09 Posts: 121
edited August 2024 in Daz Studio Discussion
Is it possible to swap out the base buildings in the Medina Cityscape Generator for custom ones? I need to make a sprawling ancient chinese city and im hoping this would work.
https://www.daz3d.com/medina-cityscape-generator
Post edited by nynico_8c2302db09 on
  • LeanaLeana Posts: 11,804
    Not sure if you could get it to work with other props directly, but maybe you could combine it with Alienator Pro to replace the various objects afterwards?
  • You can replace the duf's in the, Data\V3Digitimes\Desert cityscapes\IRAY props, folder and as long as you rename them to the original name, seems to load assets just fine.
    I tested with swapping out some stonemason buildings from urban sprawl 3 and it loaded them just fine, other than i needed to turn the z offset to 0 to keep them from floating.
    Seems to be limited to the 35 files included though.
  • crosswindcrosswind Posts: 7,821
    edited August 2024
    If you haven't bought that product, I would suggest you a no-go as it's limited in terms of functionality.. especially if you don't need those "assets in Medina" ~~
    I suggest you either consider this product https://www.daz3d.com/flockit Or, no need to use any Product at all but just use DS built-in Align plugin to manipulate your ancient Chinese city Props (or anything...), so as to wisely save some of your money ~~
    For instance, up to your need, align Figures / Props on X Axis firstly with setting To Grid values (ss1) ... then make sprawling variation by tweaking To Grid values on Z Axis (ss2) ~~
    2560 x 1392 - 1M
    2560 x 1392 - 1M
    Post edited by crosswind on
  • kprkpr Posts: 117
    You can also do it with Ultrascatter Pro and maybe just Ultrascatter... placing different "planes/discs" on the terrain where you want different types of "buildings" to be. You can do the same with vegetation, characters, vehicles and anything else you can instance. Currently $45 for the pair, but on sale often enough.
    This is perfect, thank you!
    I already own Medina, but thank you for the the Align plugin tuturial, i've struggled with it!
    I own Ultra scatter advance but have struggled with it in the past, maybe i need to check it out again.
    Too complicated for me. lol Thank you though
