Default dForce settings on the new Kaede Kimono
![Tirick](https://delorean.daz3d.com/forums/uploads/userpics/970/nF97A07806EF9.jpg)
Just some advice, if you are struggling as I did initially. The default Bucking stiffness is far too high imho for this set. It produces very odd draping on the sleeves. I turned mine way down to 15% (from 80%) and had much better results in simulation. ymmv, but some adjustments are absolutely needed out of the box, unless you want very stiff and non-simulated sleeves.
https://www.daz3d.com/bw-dforce-kaede-kimono-outfit-for-genesis-9
I attached my settings, where I further tweaked a few things, but you can see the difference, which was largely from the bucking change.
This is using a 2-second transition and 2 second stabilization, as I initially thought it needed more stabilization to drape.
Tirick
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/2d/cefe6441414ee5da8d7c2e2eff27cd.png)
714 x 863 - 349K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/5d/07670a45e046d55d1fcae57119c498.png)
802 x 823 - 899K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/56/538fb35557df0bcf62d219e7df1e79.png)
718 x 862 - 336K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/45/baf6d82f48015b81a88a89dab98c0f.png)
822 x 823 - 925K
Post edited by Tirick on
Thanks for posting. dForce items are sometimes tricky to use.
