No root found Sublime Vava Voom Hair colors
I'm having trouble with this product https://www.daz3d.com/sublime-hair-kit-for-dforce-vavavoom-hair ;
It doesn't work when I try selecting different nodes, the figure, cap, and the hair all don't work to apply to H.Materials. Here is the error log saying "no root found"
2024-08-22 22:08:07.033 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Hair/dforce VaVaVoom Hair/Materials/3DSHrKitVVV/SublimeVVV Hair Antique.duf
2024-08-22 22:08:07.046 [INFO] :: Determining missing assets...
2024-08-22 22:08:07.140 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2024-08-22 22:08:07.140 [INFO] :: Error loading asset: C:/Users/Public/Documents/My DAZ 3D Library/data/cloud/1_86171/people/genesis 8 female/hair/dforce vavavoom hair/materials/3dshrkitvvv/sublimevvv hair antique.duf
2024-08-22 22:08:07.140 [INFO] :: Operation failed
Am I doing something wrong? Any help would be appreciated.
  • felisfelis Posts: 4,617
    It is because it is set for G8.1F. So if trying on G8F it will fail.
    You can, if you want, change it in all the duf files from Genesis8_1 to Genesis 8, and Genesis81 to Genesis8.
    Then it should work.
  • crosswindcrosswind Posts: 7,867
    edited August 2024
    You can simply change the Node Name of G8F to G8.1F :
    Select your G8F, go to menu: Edit > Figure > Scene Identification..., change Node Name from Genesis8Female to Genesis8_1Female. Then apply H.Material Presets while having your G8F figure selected or the Vava hair selected.
    Then change Node Name back... when needed.
    2560 x 1392 - 678K
    Post edited by crosswind on
  • Thank you both very much, that solves my issue.
    I basically just use a dev model 8.1 and change the hair through that, then fit it back when I need. Had no idea it was specifically wanting 8.1
