AutoShape Enhancer for Genesis 8 Female Not Applicable When Using Diffeomorphic(solved)
pigcrazy4541_5266a3f7
Genesis 8 여성용 Auto Shape Enhancer는 자연스러운 몸매를 만드는 데 매우 좋습니다!
Auto Shape Enhancer Auto Shape Engineer를 적용하는 방법이 있나요? 번역 앱을 사용하고 있습니다. 글이 이상할 수 있습니다.
미리 도움을 주셔서 감사드립니다
Post edited by pigcrazy4541_5266a3f7 on
The best you can do is to import as custom morphs, then depending on the morphs complexity it may work fine or not. There's recent improvements for daz morphs so be sure to get the latest development version, also use spline drivers in the global settings. That said, personally I don't advise to import complex daz morphs in blender, it is better to keep it simple if possible.
https://bitbucket.org/Diffeomorphic/import_daz/downloads/
Thank you for your reply but
I tried custom morph import to morph panel, but it doesn't seem to apply
Just tested and seems to work fine here. Again be sure to update. I used diffeomorphic 4.2.1.2286 and blender 4.2.1, with the new spline drivers in the global settings.
steps:
You saved me. Thank you
