[Solved] Incorrect prefered base: is changing it in the dsf file enough to fix it ?
![Elor](https://secure.gravatar.com/avatar/55673a045f2e9265786bf0f908217a44?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F55673a045f2e9265786bf0f908217a44_100.png)
Hello,
I have the problem with this product (and maybe a couple of others, but I forgot to keep their names), Tousled Pixie Hair for Genesis 8 and Genesis 3 Female(s): when I'm fitting it on a G8F character, an autofit dialog pops up:
I looked at the Scene Identification and saw that the Preferred Base was set to 'Genesis 3/Female':
Changing it to Genesis 8/Female fixed the problem for the scene but I wanted a more permanent fix (I'm also opening a ticket so that everyone can get it too) so I searched where the Preferred Base information was saved and found that it's in the dsf file, this one to be precise: '/data/3DCelebrity/Tousled Pixie Hair/Tousled Pixie Hair/TPH.dsf', line 211234:
"presentation" : {
"type" : "Follower/Hair",
"label" : "Figure_Tousled Pixie Hair",
"description" : "",
"icon_large" : "",
"colors" : [ [ 0.3529412, 0.3529412, 0.3529412 ], [ 1, 1, 1 ] ],
"preferred_base" : "/Genesis 3/Female"
After replacing Genesis 3 by Genesis 8, everything is fine.
Is it all I need to do or is there something else somewhere else that could come back to haunt me ?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/bb/5c927a896a938b052f6def177c7162.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/dd/02bdaf11d5ceef0da4f910e7085103.png)
Why don't you just use the Genesis 3 version? There is another...
Right ~ though there're G3/G8 versions but both of Preferred Base are set as Genesis 3 ~~
Job's well done ! That was just what you had to do with DSF, nothing else...
I'm using the Genesis 8 version because I want to fit the hair on a Genesis 8 character and it's the Genesis 8 hair that has a wrong Preferred Base (as far as I can see, the Genesis 3 version of the hair is working fine on a Genesis 3 character).
Edit:
@Crosswind: Thank you.
I'll be sending the ticket then, so hopefully, anyone else will be able to enjoy a fixed Genesis 8 version.
It's very kind of you ! Thanks !![yes yes](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
Ah, sorry, I misunderstood the problem. Yes, changing the .dsf file will be safe. There should be a ticket, though, to get the change done officially.
I'm doing it for my past self, who wouldn't know how to fix it![laugh laugh](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/teeth_smile.png)
No worry, it was a useful misunderstaning: I rewrote my ticket's draft before sending it and made it extra-clear I was speaking about the Genesis 8 hair on a Genesis 8 character before sending it![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
Hello,
I just received an answer from Daz support and an update was pushed today and it does solve the problem![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
