Pls help to identify hairs in these promos
![i53570k](https://secure.gravatar.com/avatar/93c70c412e97281a19d1b031789745a6?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F93c70c412e97281a19d1b031789745a6_100.png)
[Pls help to identify hairs in these promos]
First is dforce sleepy outfit for G9: https://www.daz3d.com/dforce-sleepy-outfit-for-genesis-9
Second is dforce smolder dress for G9: https://www.daz3d.com/dforce-smolder-dress-for-genesis-9
I've seen similar hairs but really want to know hairs that are exact to these promos. Both hairs are further pulled back with higher hairline than anything I've seen. The bun in the sleepy outfit promo also sits much lower.
Thanks
Smolder has already been asked aboutr https://www.daz3d.com/forums/discussion/699081/hair-identification/p1 (no reply yet), I am not seeing an existing request for the other
Smolder is this
Soiree Glam Hair and Ponytail for Genesis 8 and 8.1 Females | Daz 3D
Has it had a new texture applied in the smolder promo?
Yeah it has to be since the base presets are for the Dual Lobe Shader. and they look pretty bad at that. Not sure why they used it on that since it isn't strand based. With that said, you would need to convert that surfaces to Iray Uber and use your favorite regular hair textures and then make some custom Cutout Opacity (Tr) textures for it. THEN you need to make some morphs to correct for the hair band being hidden and un-smushing the underlying hair, (which in the promo from behind i thought he spotted how he had done just that, but i was also tired when i first studied the promo's so could have been seeing what i wanted to see) along with making that tail a little fatter at the top (which can somewhat be done with scaling a couple of the bones, but moving some verts and making a morph would be better) So with all that in mind, is THAT what Romeo did? Beginning to question now if it is Soiree Glam after all. When I first looked at it inside DAZ to compare, I was sure. However, after messing with it for awhile, I'm no longer sure he went through the hassle of all that, and it could just be one I've never seen. No matter what, it is not Stock Soriee Glam. THAT is for sure.
I believe that first hair is: MEGA Updo Hair for Genesis 3 and 8 Female(s) | Daz 3D
Bear in mind that it could be that those hairs are also using the Mesh Grabber. I've turned quite a few hairs into something more to my liking thanks to that tool (adjusting hairlines as an example).
It might be https://www.daz3d.com/mega-updo-2-hair-for-genesis-8-and-81-females. There are the option with the bangs and the buns.
