Why can't I loop or ring?
TinjawTinjaw Posts: 50
edited January 2016 in Carrara Discussion
I take a cylinder and turn it to a vertex model. I then try to loop an edge and I can't. Here is a video showing my trying.
http://screencast.com/t/MsvqCC7EYBn3
Post edited by Tinjaw on
  • MarkIsSleepyMarkIsSleepy Posts: 1,496
    edited January 2016
    I'm not sure why this isn't working (maybe it has something to do with each vertex having five edges connected to it?), but out of curiousity why are you even doing this?  Why convert a primitive instead of creating a vertex cylinder?
    Post edited by MarkIsSleepy on
  • RoygeeRoygee Posts: 2,247
    This is common to all modeling software - triangles stop edge looping.  This is actually a very handy common trick in modelling.
    You would need to de-triangluate, then delete the cap to get it to loop.  But, as MDO2010 writes, why go through all that when you san simply insert a cylinder in the VM?
  • TinjawTinjaw Posts: 50
    edited January 2016
    Thanks for the info on triangles.
    This was just a simplified example. I had used two primitives in a model and then tried to bend one and could not find a way, so I tried converting it to a vertex model so I could bend it. It looks like I will just delete the primitives and start with a fresh vertex model.
    vertex points are numbered. suspects mebbe out of order
