Help Identifying These Pyjamas?
Eljayco
in The Commons
Hi,
Does anyone know if these pyjamas are available anywhere please?
https://www.daz3d.com/fg-streamer-poses
I've searched for PJ, pyjama, pajama and gamer here and at rendo but no luck so far though I've probably missed them knowing me.
Thanks in advance.
Not sure, but the bottoms of these are kind of similar. You could just put a different shader/texture on it. https://www.daz3d.com/street-style-nyc-outfit-set-for-genesis-9
I just scrolled through all 21 pages of shaders in the Daz store and didn't find the one on those pants, but I could recommend some that are similar.
https://www.daz3d.com/ready-for-bed-pajama-set-for-genesis-8-female-s
Maybe for the bottoms?
Thanks all for the suggestions. They seem close but not convinced they're exactly the same but never mind.
Do Fuguzi and Ironman have a presence here on the forums so I could maybe message them direct does anyone know?
If you put "@vendorname" (e.g. @fugazi1968 or @ironman) in a forum post they may (depending on their forum settings) get a forum notification with a link to your post. Whether they respond is another thing, but some vendors do. Since I did that here they may notice this thread.
Otherwise you can try contacting them by sitemail at Renderosity (fugazi1968, ironman).
I have these, but never used them, so I used the opportunity to give them a test run. They're pretty old so not dForce, but they work very well out of the box, also with G9F using autofit, as in render one here. Works with some poses using a dForce Modifier (render two, sitting on table, dForce on pants only). Just make sure that the pants don't touch anything other than the character during simulation, otherwise they will explode (I hid the table and moved the character upwards while simulating).
Textures are from the Expansion set.
Thanks @Taoz I'll try via Rendo.
I actually found out that I have those too, I really need to sort my assets out :D
I have zero idea how I've gone through the entire catalog as many times as I have and still missed those, but thank you for linking them. With the texture set added on they're perfect for two of my people. Appreciated!
