Problem with Zeddicus products?!
![Keiku](https://delorean.daz3d.com/forums/uploads/userpics/089/n0ONLWZ8LU8K2.png)
I recently ran into an issue with Zeddicus products. So far just two: "Z Nail Salon for Genesis 8 Female" and "Z Drink Up"
Clicking on DUF files results in Daz wanting to close the current scene asking to save changes, rather than applying the materials to the figure in the case of Z Nail Salon, or loading a prop in the case of Z Drink Up.
No idea why this is happening. I installed these same as I do anything else and I've never had issues with Zeddicus products before.
It is morphs?!
What does your log say Help > Troubleshooting > View Log File?
There are a ton of "Formula target property not found" warnings.
I should also say, I manually install all of my content.
Not sure it's Zeddicus peoducts but I have had a similar issue. It seems to be predicated on the fact that what you are trying to load Daz Studio thinks is a scene file. To circumvent the issue, right-click and select Merge into scene.
"Merge into scene" works for the material files (Z Nail Salon).
For the props and materials under Z Drink Up, it throws an error saying "No importer for the file format can be found.". I think there are some odd duplicate prop files as well as materials under the poses section, because I do have working props also. The non-working ones show a thumbnail with an exclaimation point. Perhaps I can just ignore those.
I don't have any issue with these two products. As for your DS log, it tells nothing about the products. You should firstly load the problematic DUF files, then save DS log for attaching it here.
As for the thumbnail with an exlaimation icon, if you cannot map any user-facing file in your Content Library, yes, just ignore it.
