Looking for a Shoulder Strap Belt to Add Gadgets or Weapons too for G8F
![SinisterSh0t](https://secure.gravatar.com/avatar/e0aceb4f3d8ef450dc3fb0197f817d81?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe0aceb4f3d8ef450dc3fb0197f817d81_100.png)
So I'm looking for a Strap Belt that goes from the Shoulder to the Waist, Around Front and Back. Without a Main Belt that Goes around the Pelvis as I just want that Strap Belt Element.
I want to use such a thing for adding tools like Torches, or weapons like Grenades across the length of the strap. But so Far I've had little success with finding that in the Daz Store.
When I've searched for belts their more like tactical belts that go across both shoulders and the stomach which isn't what i want.
And the shoulders strap belts i have found end up with a second main belt across the pelvis which when removed or hidden breaks the shoulder strap.
Would Appreciate any help offered to find such a product or for someone to modify a current product to what I'm looking for please for G8F.
This is the waist belt: https://www.renderosity.com/marketplace/products/140456/fantasy-sword-belt-for-genesis-8-female
Thanks, But that's not what I'm looking for.
I'm looking for a Shoulder Strap Belt without the 2nd Waist Waist Belt as Part of it.
So you just want the sash. The only thing I can think of that has that is this: https://www.daz3d.com/dforce-giuro-vendetta-hd-for-genesis-8 It works on both genders and the guns can be deleted.
Just a thought, have you looked at steampunk outfits? Not my groove, so I don't know what's in the store, but IRL I've seen people cosplay that genre and have a sash with stuff on it. Might be something you could lift from one of those?
Thanks, I'll look into it. Hopefully I can also Remove that Shoulder Plate on it as well as It wouldn't really fit with the Project I'm working on.
Desperado HD Expansion has a bandolier, not sure how much work would be required to hide all the bullets if you don't want them. dForce Medieval Peasant has a shoulder bag you might be able to use, and a more modern style in Dystopian HD, which also has a chest strap. There's another chest strap in dForce Southern Seas, another in Raider, and another in Wildenlander Watch.
It can be hidden. It's a seperate surface that can be turned invisible.
The Dysptopian Outfit looks intriguing, and has A Similar Sash Which Could Work, But it's for Genesis 8 Male. If I applied it to G8F, Won't it just break off the moment I moved or posed the Character?
Is there a tool to make that clothing compatible?![](https://gcdn.daz3d.com/p/82542/i/dystopianhdoutfitforgenesis8and81males03daz3d.jpg)
You could try autofitting, you could change the scene identification, or you could use the Cross-Figure Resource Kit.
Would this work?
I think the normal anme for this is a Sam Browne. That may or may not help with searches - I am sure we have had at least one previous forum thread, though not sure for which figure.
That could Certainly work, which product is that from?
I made it.
It is modelled to fit G8F, but I have saved it as a prop, as I assumed if it was conforming it would deform based on the character. It is saved with 4 bones, so you can adjust it with the bones.
If you want it conforming you can load it and run transfer utility.
In the file it is as a rigged prop and as a wearable preset for G8F.
It is fairly low poly, so there is defult a subD. The textures is simple, but you can apply own shaders.
Let me know if issues.
If you own Dystopian Outfit, it's very easy to Auto-fit it to G8F but some fixing work may be needed.
I roughly made one Sash ?, Left and Right versions ~ See if they're what you want. I've not made any morph on them, just rigged and shaded ~~
I'll give this a try, thank you.
