Nutcracker Mouth not opening
I am trying to use the g8 nutcracker figure and when I try to open the mouth, his mouth, mustache and lower part of his hair stretch. And the mouth doesn't open.
I have attached two images. One with dial at zero for no mouth open and the other with the dial at 100% for mouth open.
1356 x 760 - 265K
1326 x 749 - 266K
  • GordigGordig Posts: 10,168
    Have you tried it on a G8.1M? That's what the Nutcracker was made for, and G8 and G8.1 have different facial rigging.
  • Thanks Gordig, that's what it was. I wasn't using 8.1.
    The rigging is the same, but the pose controls are different.
  • nemesis10nemesis10 Posts: 3,485
    edited September 2024
    Ah, I checked and the mouth controls are FACS driven in the anatomy called Nutcracker mouth and you do need to use 8.1
    Post edited by nemesis10 on
  • crosswindcrosswind Posts: 7,816
    You can use it on both G8M and G8.1M but before loading Nutcracker's Figures onto G8M, you have to change Preferred Base to G8M (in Scene Identification...) to avoid auto-fitting. It seems to be that you didn't fit Nutcracker's anatomies to G8M... So no conforming, no effect of posing / expression...
    Mouth Open properties work on both G8M / G8.1M (if you've already removed dummy blockers in G8.1M's data folder...)
    2560 x 1392 - 1M
    1560 x 835 - 508K
    Post edited by crosswind on
