[Released] Chronos: Halls [Commercial]
The Chronos collection will take you through different eras, sporting both ancient hallways of sandstone bricks and sleek sci-fi paneling. Each temporal variation also includes a carved appearance, the ancient sandstone with copper and the sci-fi panels with a dark blue.
This hallway builder pack allows you to build your own hallway system with a large number of pieces that can be overlapped and connected to allow for many possibilities for creating unique hallways with twists and turns! Your hallways could be part of a ship, or an ancient corridor beneath a pyramid. They could be tunnels used on a planetary base with windows allowing you to take in the sights from the safely of its halls, or as part of an ancient complex left behind by a forgotten civilization.
This builder comes with several floor pieces, many combinations of hallway pieces, three types of arches with combinations of paneling available and connector pieces that allow the hallways to split in two directions or to turn the corner.
Each arch is build with a base model, that can use a simple or lightstrip version and be combined with two types of paneling of which you can hide pieces to create distinct looks and reveal lightstrips hidden beneath the paneling.
The hallway pieces contain both emissive surfaces that can be turned into windows with the included material presets, or left as is to create ambient lighting. The ancient textures provide a crystalline warm glow, and the futuristic textures provide a starry sky style emissive surface. Lightstrips adorn most pieces of the set to allow you to customize the level of lighting (and magic or technology) you with to infuse into your environments.
Two texture variations, each with their own trim that can be applied, allow you to create either a sleek futuristic look or an ancient hallway look, perfect for both fantasy and scifi scenes involving your characters!
Also provided are three prebuilt hallway sections to allow you to start rendering immediately.
Hope to see your renders with it!
