help fix eyelshases in blender
how to fix this? everytime i import to blender i always encounter this problem especially in the eyelash section, i use genesis female 8 figure
1350 x 1030 - 838K
  • The transparency map, which breaks that plane up into separate lashes, has not been applied by the transfer (how did you do that)? You should be able to reapply it in Blender.
  • crosswindcrosswind Posts: 7,853
    Use Diffeomorphic Daz Importer or Daz to Blende bridge... they both can correctly set the shader nodes on eyelashes, otherwise you have to manually set it.
