DAZ Layout Issue
When I changed the Workspace layout to City Limits the Viewport pane (middle) is overlapped by the Right Panes (DAZ Pane Issue). I've hovered over the right pane get the "edge" cursor and dragged right to resize but won't move anymore and overlaps the Axis and Rotation, etc, icons. Using 4.22.1. Beta bulid. See atachments.
296 x 988 - 58K
1920 x 1040 - 202K
  • felisfelis Posts: 4,692
    Try to close 'Shader Mixer' in the same tab as Viewport.
    This worked. Thank you.
    Why was shader mixer tab causing this?
    Panes have a minimum size and that for Shader Mixer is large enough to be a problem with both side-docks open on some screens.
    To my understanding, it has a minimum width, so it will expand the area to that, even when not the active pane.
