Duplicate Formula Found
What do I do about this error? The error appears when loading a scene but it doesn't say what is duplicated. And the log file contains no errors. There are Adjust Right Ear.dsf  files in a bunch of Hair products, if that even has anything to do with what is wrong.
573 x 455 - 52K
  • felisfelis Posts: 4,614
    What does your log say about it, Help > Troubleshooting > View Log File
  • Nothing. I said that above.
    2024-09-14 06:04:08.917 [INFO] :: Loaded morph deltas: 0m 0.78s - /data/Prae/Jessica Hair/Jessica Hair G9/Morphs/Prae/Base/BaseFeminine_head_bs_Head.dsf
    2024-09-14 06:04:08.950 [INFO] :: Loaded morph deltas: 0m 0.31s - /data/Prae/Jessica Hair/Jessica Hair G9/Morphs/Prae/Base/BaseFeminine_body_bs_Body.dsf
    2024-09-14 06:04:08.969 [INFO] :: Loaded morph deltas: 0m 0.18s - /data/Prae/Jessica Hair/Jessica Hair G9/Morphs/Prae/Base/Uncover Eye.dsf
    2024-09-14 06:04:09.025 [INFO] :: Loaded morph deltas: 0m 0.56s - /data/Prae/Jessica Hair/Jessica Hair G9/Morphs/Prae/Base/Adjust Right Side.dsf
    2024-09-14 06:04:10.183 [INFO] :: Finalizing scene data...
    After I hit okay it starts loading jpg files. There's nothing to tell me what I might be wrong.
  • Search for "duplicate" - there should be a message telling which properties are causing the warning (usually it is a case of two morphs for the same figure using the same name and having links to the same, or same-named, second property but it can also be caused by running ERC Freeze twice on the same control property). The issue is when loading the data about the proeprty to populate the property panes, it doesn't need to be in use to cause the warning.
  • There are a lot of them. I don't understand since I've reinstalled the assets several times. What else can I do?
    2024-09-14 11:37:21.062 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    	File: /data/Daz 3D/Genesis 9/Base/Morphs/3dloki/Tabitha/3DL_Tabitha_body_bs_Body.dsf
    	URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/Zev0/Growing%20Up/Youth%20Breast%202.dsf#Youth%20Breast%202?value
    	URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/Zev0/Growing%20Up/Youth%20Breast%201.dsf#Youth%20Breast%201?value
    2024-09-14 11:37:21.069 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    	File: /data/Daz 3D/Genesis 9/Base/Morphs/meipex/GoldenPalace/GP_CTRL_MorphsNeutralizer.dsf
    	URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/meipex/GoldenPalace/GP_CTRL_MorphsNeutralizer.dsf#GP_Anus_BumpPreset3?value
    	URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/meipex/GoldenPalace/GP_CTRL_MorphsNeutralizer.dsf#GP_Anus_BumpPreset2?value
    	URI: Genesis9:/data/Daz%203D/Genesis%209/Base/Morphs/meipex/GoldenPalace/GP_CTRL_MorphsNeutralizer.dsf#GP_Anus_BumpPreset1?value
    2024-09-14 11:37:21.087 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.088 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.101 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.106 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.119 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.120 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.150 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.166 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.172 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.187 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.188 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.200 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(697): Formula output property not found:
    2024-09-14 11:37:21.216 [INFO] :: Sorting formula properties...
    2024-09-14 11:37:21.220 [INFO] :: Creating ERC Links...
    2024-09-14 11:37:21.635 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    	File: /data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/Death9_body_bs_Body.dsf
    	Owner: BreastacularG9_8191
    	Input URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/Death9_body_bs_Body.dsf#Death9_body_bs_Body?value
    	Input: Death9_body_bs_Body
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/Death9_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Enable%20Smoothing
    	Output: Enable Smoothing
    Duplicate:
    	File: E:/Docs/Daz3D/THE KISS/version2b.duf
    	Output URI: BreastacularG9_8191:/EEnable SmoothingA/Docs/Daz3D/THE%20KISS/version2b.duf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Enable%20Smoothing
    	Output: %6
    Previous:
    	File: /data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/CJ_Meadow9_Body_bs_Body.dsf
    	Input URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/CJ_Meadow9_Body_bs_Body.dsf#CJ_Meadow9_Body_bs_Body?value
    	Input: CJ_Meadow9_Body_bs_Body
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/CJ_Meadow9_Body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Enable%20Smoothing
    Duplicate:
    	Output: %6
    Previous:
    	File: /data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/VYKMyrrh_body_bs_Body.dsf
    	Input URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/VYKMyrrh_body_bs_Body.dsf#VYKMyrrh_body_bs_Body?value
    	Input: VYKMyrrh_body_bs_Body
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/VYKMyrrh_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Enable%20Smoothing
    Duplicate:
    	Output: %6
    Previous:
    	File: /data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/JS_Micah_body_bs_Body.dsf
    	Input URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/JS_Micah_body_bs_Body.dsf#JS_Micah_body_bs_Body?value
    	Input: JS_Micah_body_bs_Body
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/JS_Micah_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Enable%20Smoothing
    Duplicate:
    	Output: %6
    Previous:
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/Death9_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Smoothing%20Iterations
    	Output: Smoothing Iterations
    Duplicate:
    	Output URI: BreastacularG9_8191:/ESmoothing IterationsA/Docs/Daz3D/THE%20KISS/version2b.duf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Smoothing%20Iterations
    	Output: %6
    2024-09-14 11:37:21.636 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(989): Duplicate formula found:
    Previous:
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/CJ_Meadow9_Body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Smoothing%20Iterations
    Duplicate:
    	Output: %6
    Previous:
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/VYKMyrrh_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Smoothing%20Iterations
    Duplicate:
    	Output: %6
    Previous:
    	Output URI: BreastacularG9_8191:/data/meipex/Breastacular_G9/G9Breastacular_Graft_Base/Morphs/meipex/Update2/JS_Micah_body_bs_Body.dsf#DzMeshSmoothModifier?extra/studio_modifier_channels/channels/Smoothing%20Iterations
    Duplicate:
    	Output: %6
    2024-09-14 11:37:23.658 [INFO] :: Finished resolving formulas.
  • Check for an update to that product, if there isn't one check you don't have two different versions installed in different content directories 9in whichc ase DS might be findiing an older, bad file first) and if that fails contact the creator.
  • I don't know how to contact the creator. That's I posted here.
    And I shouldn't have two versions as I only bought it in early August. Having more than one directory though is a possibility. I can't stand when programs assume the C: drive can hold everything.
  • Presuambly Miepe at whichever store you purchased Breastacular - Renderotica? Or perhaps they supply support, the way Daz does for its PAs, so you might also try the support link for the store.
  • hi i dont think that the prob. is with the product. it started 2 weeks ago with me.
