Can I delete Daz Content cluster?
I don't know what it is for but I kinda need space and the whole thing takes up 60 gb so I wanna get rid of it, what will happen if I delete it?
  • That is th database used by the Content Management System, deleting it would be a bad idea. You can chnage its location, if you have more space on another drive, via Edit>Prefrences>CMS Settings for example, though you will then have to copy the Content Cluster folder from the old location to the new (with all applications that might use the database closed).
  • Ok, thanks, amma leave it where it is.
  • crosswindcrosswind Posts: 7,816
    60 GB sounds not normal to me... how many product have you installed ? I've had 27K products installed and the size of cms cluster folder is 7GB.
    You better check and Condense Databese with Content DB Maintenance tool ~~
