Can't run Daz Studio
![sondroal](https://secure.gravatar.com/avatar/d5244c6fc3ca5aa85fa43c5952533a44?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fd5244c6fc3ca5aa85fa43c5952533a44_100.png)
Hello, I just installed daz studio and tried to run daz studio 4.22 on installmanager, but I couldn't run it with the phrase 'DAZ Studio has encountered a fat error, and must close'.
Is there a solution? I'm using windows 10 and pc spec i9 13900K and rtx4080
Exception Reason shows ' DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Windows\SYSTEM32\OpenCL.DLL" at 0033:00000000F82924AC, clGetPlatformInfo()+12 byte(s) '
Registers
RAX=0000000001FFECD0 RBX=0000000001FFEE40
RCX=000000005F1A7E90 RDX=0000000000000902
RSI=0000000001FFECF0 RDI=0000000001FFEE40
FLG=00010206 RBP=0000000000000902
RSP=0000000001FFEC18 RIP=00000000F82924AC
OpenCL is used, as far as I know, only for the dForce simulation engine (dynamic hair and clothing) which wouldn't be active at launch, although it may well do a version check to get the list of available engines. An error like that is probably driver related - either the nVidia GPU driver or, if you have it, the Intel CPU driver for OpenCL. Do you know if you have the Intel driver, and if so what version and what nVidia driver version do you have?
