PW Mansion crashing out DAZ studio with less than half load
I am trying to load PW mansion in DAZ Studio but it is constantly closing out and will not load. I checked the load and it is not passing 49% RAM and 30% GPU so this is not hardware related. The quote is stating...
"DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\dzfilamentapi.dll" at 0033:0000000033CB5147, std::vector<unsigned char,std::allocator<unsigned char> >::_Xlength()+505515 byte(s)"
How am I supposed to get this to work?
  • crosswindcrosswind Posts: 7,853
    edited September 2024
    Pls try pressing Ctrl + 9 before loading the mansion... i.e. loading PW Mansion with Texture Shaded drawstyle.
    Post edited by crosswind on
  • It is working with that selected, what is causing it on the other texture mode?
    TBH, I don't know... I never use Filament drawstyle but just the error message you posted indicates to it. Probably the issue results from the shader conversion with Filament ~~
  • Thanks
