DForce Hair Help
Hello.  When i use dforce simulation something strange happens with the hair. How can i preserve curly shape of them in simulation?
The hair is this
The pics shows what hair appears before simulation and after. Settings used are default setting.
Thank you
773 x 860 - 370K
773 x 860 - 367K
  • dForce hair is a fickle pain.  If the hair has too many points, its going to melt when you run a simulation.  If it doesnt have enough points, it will refuse to drop at all.
    My advice is to reduce the amount of ps/ pr points on all the surfaces.  If it's set to 30, drop it to 20 etc.   With the new curves, it doesnt need to be set super high.
  • crosswindcrosswind Posts: 7,841
    edited September 2024
    Select the hair, go to Surfaces pane, filter out Local Shape Constraint Stiffness property, set its value > 0.5
    Default value is 0.9, the vendor set it too low (0.1) ... so the natural curly shape cannot be preserved while draping ...
    2560 x 1392 - 1M
    Post edited by crosswind on
  • Really thank you
