Mesh Grabber in Beta?
![CAV_18687](https://delorean.daz3d.com/forums/uploads/userpics/017/n610R1Y2GUXO8.png)
Howdi All!
Can Mesh Grabber be used in Beta?
I can't find it and don't know where to start in terms of making it appear in Beta...
Any help would be greatly appreciated...
Howdi All!
Yes, it works fine in Ds Beta. If you installed the Beta after installing Mesh Grabber, try reinstalling Mesh Grabber. Hopefully you are doing your installs with DIM.
So yes for a long time ive done them with DIM, what is the problem with the connect installs? How would I know which products I did that way now? Ill try the Mesh Grabber reinstall now, Thank you so much!
That's sorted it! Thank You barbult!!!!!!!!!
Problems with Daz Connect install method:
I have completely given up on Daz Connect. I purged everything Connect related, and I only use DIM. It is really best to only use one install method. Anything else leads to confusion and problem. I think DIM is the one and only reasonable way for me.
Great!![yes yes](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
How is this done? I hate seeing some stuff in Connect and some not.
Uninstall everything, make sure that the General Release is not set to log in or that the Beta is not set to update metadata, then you can select all the products, right-click>Delete.
barbult, thank you so much for taking the time to write this response, I hadn't quite managed to pick up on the why's and wherefores, so this helps immensely!
Do check http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_22_1_174 for information on how Connect handles clashes between user and vendor (store) metadata.
I'm pretty sure I don't understand all aspects of that.
I think the chnages mainly relate to metadata handling, so DIM certainly won't pop-up a warning and yes the Connect install would still take precedence.
Thanks for the clarification, Richard.
