An exporter for Poser users
WendyLuvsCatzWendyLuvsCatz Posts: 38,206
edited January 2016 in Product Suggestions
well if DSON has had its day and content is moving to DAZ Connect, how about a better Poser format exporter for DAZ content to compliment the other newer formats like Alembic, etc that are now available?
If it needs to be a paid plugin, most will accept that if and only if it does  a decent job creating cr2 files with geometry etc without a lot of fluffing about, yes you can do it now but it is not a one click solution, ideally it should only need the Connect Authentization part of DS and library access without having to learn the program for those simply wanting to use assets, after all Max, Maya, C4D users too really only want a mesh to export maybe rigging and morphs, so basically a DAZ content downloader convertor for people wanting to use DAZ assets
maybe even export some dufs for Carrara 8.5 users cheeky
after all the landing pages says ....
1534 x 249 - 50K
  • LeanaLeana Posts: 11,693
    There is already a cr2 exporter in DS, and it works well. People used it for Genesis content before DSON importer was released.
    The main problem is that Poser doesn't support some of the features that DS content uses, and that the DSON importer plugin manages.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,206
    Yes it is doable, I used MidnightStories tutorial and got G3F in fully rigged with morphs and made a mimic export from the cr2 in Mimic pro even so she could talk, but it was hardly a one click solution.
    what is needed is a simpler way like the D3D DSON loader does within Poser without having to work in studio, why I suggested a connect library interface that just exports to various formats including just obj even since obviously the duf does not exist to be used.
